Is there a way to change the number of undo levels on the iPad?
Az undo levels cannot be changed on iPad. (neither on any SketchUp).
Thanks for the info!
I tested this, and iPad seems to have the 100 levels of Undo that was the case in desktop until a few updates ago. The desktop limit was raised a lot. I will ask if there is a reason iPad is using the older lower limit.
Probably because SketchUp for iPad uses the same engine as SketchUp Web
All of the clients use the same underlying engine, but the Undo feature may vary. The web version does seem to be limited to the old 100 undo actions. I will ask both teams why they didn’t increase it.
Or why can’t we configure the limit ourselves
