Hi,
I have been using Dynamic Components every day it feels like for the past 6+ years, in the video you mentioned you hoped more people would use Dynamic components on products, I have done just that.
In 2014 I was tasked with creating a way to Invent a new Steel Framed SIP Panel Residential Housing System here in Australia when our Draftsman pulled out of our Startup, I decided to go with Sketchup and taught my self, at first I was only using it for Manufacturing Drawings of our components as we had another program that suppose to do the estimating with another program called Buildercost.
When the other software didn’t work out, I start researching Sketchup and was when I learned about Dynamic Components & the Generate Report function with the ability to export a .csv file… this was a game a changer… The estimating software I was working with could read .csv files and only needed a Qty, Itemcode and length or m2 amount showing and it could create accurate purchase orders… sort of… never seen an Estimating program to date that can do the basics of 3D Modeling Estimating & Purchases from a .csv file… hence why I write this…
I have modelled hundreds of modelled components with Dynamic Component custom Attributes assigned like Name, Itemcode, Length, Width, Thickness, Type, Colour, Weight, Price, Supplier.
I used basic Excel formula’s to calculate what can change within the model it self like length, weight, thickness, width using the LenX, LenY, LenZ
for eg, My Custom Attribute is Length: my code looks like this =LenY*10
My LenY in my model just represents the Axis length and im just assigning a code to attached to it, I increase the length of Model it increase my Length Attribute, im sure u know this but for people didnt…
my biggest problem right now is,
When I model a home out of the components it will be built out of using all those dynamic attributes so I can create an accurate list of ordering materials and price, some times I need to edit a beam or post and the moment I make it its own component or I do edit it , it changes all my other copied models…
The problem attributes are Price and Weight, they are created off the models Axis and if my pricing increases from suppliers and I want to update my models I would have to search down every individual model within that home and change the price manually… this fundamentally makes sketchups estimating system within sketchup not completed,
Im in the process of creating a software program that can read less attributes in the .csv file but boy it would be cool to have this all done with a dynamic component frame work.
