This may just be because it’s early and I’m not understanding, but can you expand on this a bit? What do you mean by “assemblies?” Based on these examples, I would assume that this means that you can create multiple different iterations of the same Live Component and combine them into a single item (an “assembly”)?
Is this something you do manually by grouping the individual iterations within SketchUp?
I just hope they are going to enable global edits, so you can change the color or door style of ALL the cabinets in the model derived from the same live component (or maybe just a selection), even though most of them will be unique components due to different widths and door/drawer configurations.
If you have to manually go through each unique cabinet component and change the color one by one, that will be really disappointing.
Global edits would be helpful to so many types of objects. Windows: Change from wood to vinyl in one click, or change the interior trim in one click, regardless of the fact you have different sized windows in the model.
Safari doesn’t support our model viewer very well. I will add this to our known issues list. Chrome is recommended. Firefox is ok, New Edge should also work pretty well too.
I love the real time feedback of changes to the model as you change parameters. Want to make that REALLY cool? Put handles on the model part that might correspond to a variable and let the user push/pull that handle in the model while even drawing on inferencing in the process. For example, for the height of a stud wall, grab the top of the top plate and drag it up and down and use inferencing to align with something else in the model. That would be an advancement as profound as the original SketchUp patent.
