I’ve been using SketchUp for years with enjoyment and success, mastering the tools I have needed. I the current model, all of a sudden my components show internal lines and I nom longer have the ability to use the push/pull on some components. When I select a component and then double click on a face to enable the push/pull feature, it opens the component behind the component I want to work on. I am completely lost. Any ideas?
Perhaps you could share the model so we can see what you are describing. If these are just softened edges on the faces you could try erasing them. If the geometry has become distorted erasing those edges could make faces disappear. Then some other fix is required.
Hi Dave R,
Ok, so this is weird. I decided that instead of sharing the whole file (a cabin renovation), I would copy and paste the components that I was having problems with - in this case some lower kitchen cabinets and countertops. When I copied and pasted them into a new file so they were isolated, the internal lines were not there and the push / pull feature worked as normal!!
Xray = View > Face Style > Xray > toggle on / off [there’s also a Toolbar with button toggle…]
OR
Back-edges set in Style
K = toggle on / off…
EDIT: late to the party by 1 min !
This is my first time using a Forum for help and I am totally impressed with the speed and knowledge shared. Problem resolved. Thanks again, everyone!!
