How to make "Back Edges" invisible?
Hello!
I try to help my mother with learning SketchUp. She is doing quite well with drawing, but I do not know how to fix one problem with Edges Style.
As you see, back edges option is disabled. Despite that - back edges are still visible. I tried all options in Window → Styles menu, and I have no idea, how to achieve view looking like the one visible there - Creating and Editing a Style | SketchUp Help. ( I mean the first one under “Good to know”)
I would be very thankful for any help!
You might have X-ray mode on in View->Face Styles->X-ray but it doesn’t really look like the style of X-ray mode. Are you sure there really are faces on the top of those cuboids?
Can you upload the .skp file?
Under the Face Style sub-menu, is X-Ray enabled? If not, then perhaps you could upload (using the 7th icon from the left, an up-pointing arrow) a sample model and other folks would be able to check it and identify what is causing all edges to be drawn in the viewport.
Untitled.skp (125.3 KB)
X-ray option is disabled.
I’d say it’s a graphics card issue, then. Go to Window>Preferences>OpenGL and turn off Hardware Acceleration. See if that’s changes anything. When I open the file on my computer I see this:
Does it change when turning off Shadows? They are turned on in your screen shot.
I see the same as @DaveR here, so yes it’s a graphics card issue.
It was it!
Thank you all for help!
the topic can be closed
What was it?
I mean, turning off hadware acceleration helped. Back edges disappeared.
OK. You can mark my post as the solution so others will know it’s solved.
