Installed SketchUp 2026 but can't open after logging in
Hi all, sorry I wasn’t able to update on the matter. I did submit a ticket, and they suggested deleting the ‘login_session.dat’ file in the AppData > Roaming > SketchUp 2026 folder. I have done this, and yet it still hasn’t worked for me. It still showed the same blank window as attached to my problem.
I’ve given up on working out this issue and just continued my work using the SketchUp 2022 version. However, I couldn’t use the Geo-location feature because of the issue.
If you happen to have the same problem, I suggest submitting a ticket since they do explain step-by-step. Thanks for all the help.
