Just installed SU2023. Decided that I need to wait for some things to get fixed to use it for work. Deauthorized all devices. Tried to run SU2022, and I get the standard “complete the sign in process in your browser”
Except the browser (using MS Edge in Windows 11, don’t have another browser installed) won’t open the login page no matter what I do.
I even tried deleting the WebCache folder to no avail.
Please advise. Can’t use sketchup pro for work now.
EDIT - uninstalled SU2023, rebooted, am able to use SU2022 (open & save files).
Out of curiosity, when you installed SketchUp 2023, did you do it correctly by right clicking on the downloaded installer and selecting Run as administrator?
In File Explorer under your username go to AppData/Roaming/SketchUp/SketchUp 2023/SketchUp and delete the file called login_session.dat. AppData is a normally hidden file but you can make it visible in File Explorer. Then install SketchUp 2023 using the right click and Run as Administrator method. Make sure you have the latest installer from sketchup.com/download/all. See if that helps you getback to working in SU2023.
That file doesn’t seem to exist in the directory you mentioned. However, my goal was to get back to 2022 since there were some things that no longer work (Eneroth Viewport Resizer) in 2023. I am happily back in 2022 right now.
I agree, I should have. I don’t know if it can be correlated, but while I had 2023 installed, I was unable to run 2022. I was getting the screen where it would tell me to log in at the browser…which wouldn’t open.
Once I uninstalled 2023 and rebooted, 2022 stopped giving me the “log into the browser” and worked fine.
