Installed extensions are visible and enabled in extension manager but not in menus or toolbars
System:
Mac Mini M1 - OSX 13.7.2 Ventura - Sketchup Pro 2023
I have installed several paid and free plugins (Artisan, Fredo Suite, …).
They are active and enabled in the extension manager (with unrestricted settings).
However none of them show up in the toolbars or menus (not even the standard sandbox tools).
There are no error messages at start up.
I already downloaded sketchup again and replaced the previous install.
I removed all plugins and I installed some of them again. For some reason Artisan started working again, however as soon as I closed Sketchup and reloaded it went missing in the menus again.
Any ideas on what’s causing this?
You must go to the view menu, toolbars and enable them to be shown on your screen.
Did you quit and relaunch SketchUp after installing them? Some extensions don’t “take” until you restart SketchUp.
Those look like they may have come from Sketchucation. Do you have the Sketchucation store extension installed? I believe that’s where you would control the activation of extensions you bought from them.
Colin’s point is important. All of Fredo6’s paid extensions require the Sketchucation ExtensionStore for license management. This applies to other paid extensions from Sketchucation and it is clearly spelled out on the extension pages at Sketchucation. Nearly all of his extensions also require the current LibFredo6.
You should first install the ExtensionStore tool and use it to install Fredo6’s extensions as well as any others you get from Sketchucation.
Both LibFredo6 and Skechucation Extension Store are installed.
It happens to all installed plugins (not only the ones on Sketchucation).
Every time I open Sketchup all installed plugins are missing in the menus and/or toolbars. However they are installed when I open the extension manager. I can only get them to show up when I install another extension. So for now I do have a bit of a work around, but it is an annoying issue nonetheless.
Any insight on what might be causing this is welcome.
Is SketchUp installed correctly? Is it a cr acked version of SketchUp?
This is an official payed for version.
Have you actually properly ‘installed’ SketchUp ? On a MAC it’s possible to run an app directly from its installer file, in that case all sorts of weirdness results because not all of the required files/folders and permissions are set up properly…
