Good morning
I would like to select part of a plan and print at scale 1 (only the selected part)
thank you all for help
version 17.2.2555 64bits
Good morning
Can you share the .skp file so we can see what you are working with? In general, you need to set up the file to show only what you want to print, set the camera to Parallel Projection and the appropriate standard view. Then you should be able to set up to print to scale. Possibly more gymnastics required but without seeing your model it’s hard to say exactly.
merci DaveR
tunel1.skp (19.1 KB)
sorry for my English
I would like to select a part of the plan and print at scale 1 (if possible)
merci
Select the rectangle you drew around the end. Right click on it and choose Zoom Selection. Make the model window narrower so it’s closer to the aspect ratio of the paper. Set up Print or Print Preview with Fit to page and Use model extents unticked. Set the scale on the right to 1 to 1.
it’s all good
Thank you so much
you just saved a french
thanks again
