If a building with name plate in front elevation and we have to export front elevation to AutoCAD . after importing the text break into lines and do not get recognize. is there any solution for importing text without breaking…
It depends what you call as “text”…
If you are creating the text with a Text Tool or Dimensions Tool
that will be exported from Sketchup to dwg as real text.
But if you are creating it with the 3D Text tool
that will drawn as component containing edges and faces and being exported from Sketchup to dwg as individual lines (dwg 2D export) or Block reference, containing individual lines (dwg 3D export)
