Importing OBJ in Sketchup GO
Good day,
I have Sketchup GO (which is not a category I could find in the Community).
It says here: “What's included with SketchUp Go | SketchUp Help”
that the GO version could import OBJ.
However when I try to import OBJ in Sketchup GO it says “unsupported file type”…
Any view?
Thanks and regards
The category name should be updated from Shop but hasn’t at this point.
It does indeed seem to imply that there however it’s not listed on the Import window. I expect there’s an error on the Help page and that should be updated. @colin might be able to alert the proper “authorities”.
Thank you for the prompt answer.
I don’t want to be nasty or anything, but hey it is published here “What's included with SketchUp Go | SketchUp Help” and as such should be made available. This is not (for me) just a mistake to be corrected somewhere. It’s like you buy a car that has leather seats and at the delivery time you realize they are wooden seats and you’re told there is an error in the folder.
Thanks
OH yes…indeed, it is the export…damned.
No chance for me to import an OBJ then with GO?
Sorry. The folks who write the help files are human. They aren’t infallible.
At least for the moment you can use an online converter to convert the OBJ to STL and import that. Or you can use SketchUp Pro which does import OBJ files with freely available extensions.
Thanks, it was my mistake, in GO you can export not import an OBJ.
My bad, sorry.
I’ll first try to convert.
No, it doesn’t. But there are extensions.
I converted the file. I tried 3 converters and finally found one that does not create an issue when uploading in sketchup. Thanks
The desktop version also does not natively import OBJ. The problem is that where as it’s possible to export all of the things that SketchUp can do as OBJ, it’s very likely that other 3D programs will export into OBJ some things that SketchUp cannot handle.
Other formats would have the same problem, and in the case of DWG for example, SketchUp is able to import what it can and skip what it can’t (text elements is one case). Collada could have the same issue, but as it’s XML that makes skipping things easier.
Can you go via Collada instead of OBJ?
