I’m trying to import a .obj file into Sketchup and it’s not letting me access the file. I’m able to open the file in Adobe Dimension as a corona.fbx file, but when I convert it to a .obj file to try to import it doesn’t work
SketchUp doesn’t import OBJ or FBX. With this extension you could import glTF or glb files:
https://extensions.sketchup.com/extension/62421367-d86e-44f1-82f6-088d6131cae4/gl-tf-import
You can export glTF or glb from Adobe Dimension.
ok thanks, I read that it did, so I was misinformed. guess you can’t believe everything you read online, who knew? ![]()
It can export OBJ and FBX. Maybe that’s what you read.
