Importing .DWG into Sketchup
Whenever I try to import my dwg into Sketchup, I get the following warning and the dwg imports as a single line on the blue axis. I’ve found many previous people on this forum with the same issue, but none of the solutions I’ve tried have seemed to change anything. I moved the drawing to 0,0,0, I purged everything purgeable, when I use zoom to extents it only shows the drawing I need, I tried removing blocks, I copy and pasted the drawing into a new file, and I tried removing the contour lines to see if that was causing the issue. Some relevant information is that the contours are from ArcGIS and I used the export lines to a dwg tool and whenever I open the file it says something along the lines of “warning: AutoCAD didn’t create this file, do you still wanna open it?” Here’s the dwg if anyone can figure out what the issue is. Thanks!!!
aswancontours no elevation.dwg (290.9 KB)
Warning:
Some imported geometry is extremely far from the
model origin. If you experience any instability with
your SketchUp model, please delete that geometry
from your .dwg/.dxf file and import again.
AutoCAD Entities Imported:
Layers:		11
Blocks:		2
Arcs:		35
Circles:		6
Inserts:		5
Lines:		203
2d Poly-lines:	314
AutoCAD Entities Simplified:
Coords out of range:	165
AutoCAD Entities Ignored:
Anonymous Blocks:		2
Zombies and Others:	1
SKP model (2D plan) :arrow_right: ter-02.skp (889.0 KB)
:exclamation: check the scale/units :exclamation:
Thank you! Were you able to just import it or did you have to do something to solve the issue?
You’re welcome!
I imported the dwg file and then with Fredo Scale I flattened the geometry to 0 on Z.
Cool @mihai.s I didn’t know FredoScale, which I use a lot, would allow that. Very handy!
