How do I import an image to draw over?
File > Import > Select the file format. (DWG/DXF is Pro only)
If DXF… be sure to look at the import options for the proper unit import. If you forget to select the correct units, no problem. The scale can be corrected after import using the following technique - http://youtu.be/fCdpxW0vLvc
You will want to scale the image correctly after it is imported. Here’s how - http://youtu.be/p1twIq5Uzos
Thanks a lot. That did it.
