I am trying to import the attached image into sketchup. It was originally a png which I converted to pdf and then dfx. However when I go to import the dfx I get an import failed message.
I have attached the pdf and png. (Edit: how do I attach files to this?)
I want the lines of the image to be recognised by sketchup so I don’t have to draw round every individual line. It worked for me last year but I’m stuck now . Any advice/help would be greatly appreciated as this is for a college project.
A raster image remains a raster image unless you draw over it or use some vectorizing application. Converting, as you did, to DXF, only creates an AutoCad file with the image as an external reference. SketchUp doesn’t support external references.
In older times I tried various expensive applications that were for autotracing scanned drawings. Usually cleaning up the result took more time than drawing the thing anew completely from scratch.
