Why on Earth did the option for importing DEMs disappear in SU 2022? This is one of the main reasons I use SketchUp. I will not have to downgrade back to 2021. What a disappointment!
Hmmm… It’s still available in SketchUp 2022 for me.
The import list looks the same in SU2020. I didn’t open 2021 to check but I expect it’s the same there, too.
Had to check, yes I see it too, and AFAIK I haven’t installed any extensions that would add file formats to the list.
I know I haven’t.
I also tried to import a DEM and the files were grayed out when inspecting the folder.
Perhaps @colin can chime in.
Windows or Mac?
I’m using Windows.
Do you have a M1 apple silicon Mac?
Other importers (.ifc) are (not yet) rewritten as well.
Try this/
Close and exit SketchUp
In Finder, select the SketchUp application and hit Cmd + i (info panel)
Check the ‘use Rosetta’ box
Start SketchUp.
I’m not using an M1 Mac and can see that .DEM is missing from the v2022 import list. I’ve fwd the request to look into it on our end and will let you know if/when I hear anything.
For me, any version of 2022 (I have a few of them) on my Intel Mac running Big Sur, show the DEM importer. On my M1 Max MacBook Pro running Ventura, I see the importer when running Rosetta, but I didn’t when running M1 native. I tried disabling all non-standard extensions, thinking that maybe one of those was blocking DEM, but it didn’t help.
I’m not sure why I see DEM in Ventura under Rosetta and yet not native, and Eric doesn’t see it when on an Intel Mac and Monterey.
SketchUp 22, Mac Big Sur, Intel chip. I do have the DEM import option.
This is still the same in 2023 btw
Just started a trial with 2023 on macOS M1. No DEM option under import. Is this still a lingering problem? Kind of a deal breaker for me.
I can’t find an update about this. For now you would need to Get Info on SketchUp in Applications/SketchUp 2023, and check the box that says Open using Rosetta.
You could duplicate the SketchUp app, and set one copy to run in Rosetta when you’re doing DEM importing, and use the other as native M1 to get better performance.
I got DEM files to show as an option for importing using Rosetta, but I get an error when I actually do the import, so no real progress.
Could you show a small example file that fails?
Hi, not the OP, but I also get this error when trying to import a DEM file on SketchUp Pro 2023:
DEM Errors:
File format not supported:
I have zipped up the DEM file and attached it:
stanwood.zip (45.7 KB)
It’s a valid file, I’m able to use GDAL’s gdaldem to generate a hillshade of this file:
Would love to know why I can’t import it in SketchUp. And would love it if SketchUp gave a useful error message, for that matter.
