trying to overlay building plans ( jpg) on DEM from Googleearth to model
http://forums.sketchup.com/search?q=dem
...(snip)...
DEM import is a Pro only feature.
File > Import… (Select DEM as the filetype in the dropdown control.)
JPG Images are imported via the same dialog. When they come in they are wrapped up in a component instance. (Sometimes this needs to be exploded from the right-click mouse context menu.)
JPG images can also be used as textures (for faces of surfaces.) You don’t import them. You create a new Material in the Material Inspector, and then assign the JPG image as it’s texture via a file browse dialog (similar to the import dialog, except it will by default show all image filetypes.)
I don’t know if it changed in time but that’s incorrect, according to this article both Make and Pro versions can import (i tested and can confirm).
That is what I referred to, but perhaps I misread it ?
Can anyone confirm it appears on the import dialog for the Make editions ?
There is also this other article:
Here’s a screenshot from the Windows version of 2016.
BTW, I used Windows because my Mac versions of Make are too new, and are still acting like Pro.
Okay thanks I snipped the erroneous statement. (I should get a new pair of glasses.)
