I want to download a 2d image as a texture. I’ve created a box for it to go on but I can’t scale it so that it fits on the box. I only get half the image. Can you help?
Did you import the image as an image or as a texture? Easiest workflow would be to draw the rectangle to the same size as you want the texture to be, then import the image as a texture and apply it to the face. If you imported it as an image, right click on it and choose Explode. Then go into the In Model materials select the texture, edit the dimensions.
Thank you. Sorted.
