Hi - I need help urgently. I’ve received a DWG from a consultant - and it all opens on autocad lt. However when I try to import it to SU, it comes out with a blank Import result and then an ‘Import Failed’ message.
GA Plan.dwg (2.7 MB)
I saved it back to a r2013 dwg and was able to bring it into SU. I did get a warning in Acad about AEC objects so that might also be part of the problem.GA-plan.skp (12.5 MB)
Thank you so much
No problem and I hope it helped
