I am having difficulty importing the attached file to SU. I don’t usually have any problem and this is a UK Ordnance Survey drawing that should be completely kosher. However, there is a warning immediately after import. When I dismiss it, I see the imported drawing briefly and then SU immediately falls over. Can anyone think of a workaround? I do have to get this drawing into SU somehow.
Try un-checking “preserve drawing origin” in the import options. The drawing is a long way from the origin. But, it comes in fine for me both ways. I could just pop you a SKP if it doesn’t work for you.
The DXF export settings in CadStd where set to: ‘Export all visible layers’
Thus, all 16 Layers came into SU, because there are only 16 layers in CadStd, including Layer0
No, it had a name, just a number actually, there is no means to ‘name’ layers in CadStd.
But there was nothing assigned to that layer.
Before posting the model I did a little renaming of the layers in SU to restore order.
