I have a issue with importing .ifc files in SketchUp Pro. It looks like there is a issue with the .ifc import function where every object is filled with one color.
The following steps were made;
I have created a number of different windowframes in SketchUp.
I export them as an .ifc
When I import this .ifc-file back into SketchUp all the windowframes are filled in all different colors other than generated.
It looks like the last generated color in a object/Windowframe is used for the complete object.
a. Am I doing something wrong?
b. is there something wrong in the .ifc?
c. is there something wring in the way I import the .ifc?
d. a bug in the export/import function of SketchUp?
e. something else?
In the enclosed attachments you’ll find the screenshots, .skp and generated .IFC.
Is it the exporter or importer that is behaving weird in this case?
EDIT: also, the thing is: ifc.is not intended for material (as in object colorization) transfer (hence the lack of textures). It is intended for Building Information. From the screenshots, since i have absolutely no view on the transferred properties of the objects, I judge they both are perfectly the same and valid, bim-wise.
thank you for the reply. I’m already using the BIM tools IFC manager.
Our standard procedure is to generate our .ifc’s with the BIM-Tools exporter and our clients are always happy with the properties of the model. So the data is not an issue. It’s solely the import in SketchUp.
And it looks like both the native and BIM tool exporter are doing just fine. When I import the .ifc in Trimble Connect I see a perfectly fine model, as do our clients who mostly view it with Revit. So it is kind of strange that that all other tools are handling the colors fine. Also worth mentioning is that when I load revit generated .ifc models all the colors are imported just fine in SketchUp.
So, if I understand it is the combination of native export > native import behaves bad? But, native export > other tool import is fine? And, other tool export > native import is fine as well?
Hi Kenkey, I just looked into it, and while other models looks fine, it looks like those windowframes are build out of all separated .ifc windows. that is probably why those windows look fine. But every element is indeed build in one color. So I think the conclusion so far is that it is not bad, but consistent.
During the native IFC import, SketchUp reads the material properties, but at a classified object level.
Unfortunately, the material names are replaced by SketchUp in the form of < auto1 >, < auto2 > etc.
Basically, sub / child objects that are not classified inherit a color from their parent object.
