Problem ifc can't import buildingelementpart
Hello everyone
I use sketchup for construction site methods, this requires the import of an ifc model, but recently, ifc identifiers of the buildingelementpart type have appeared, sketchup does not know how to import the geometry of this type, as a solution I use export trimbleconnect trinbim, however we persevere the ifc tree, is there an update planned to correctly import the ifcs with this type of element?
thank you in advance for your feedback
How are you importing the ifc file? Are you using Ifc Manager?
thank you for your answer,
yes I use ifc manager 5
but same result as the classic sketchup import
here is a capture import into sketchup
