before iamge:
after
I want to project this local on this object (it’s a little bit curve)
I did import the logo at an “image” instead of “texture”
But I failed to do so. what should I do?
*****edit: new
okay, I think the problem my surface is not evenly connected. How could I connect the surface to make is smooth?
mihai.s
2
Right click on ‘Image’ > Explode (it will turn into a textured face)
Right click on the face with the texture > Texture > Projected
Learn the basics of SketchUp at https://learn.sketchup.com/
thanks I got it now.
Should i “reply” thanks everytime there is a solution?
Cause the website suggest
“ony replace if Ihave additional details or the solution doesn’t work for you”
mihai.s
4
You’re welcome!
It’s up to you.
That message appears in threads that have a checked solution and you want to add a reply.
