Hello,
I need to wrap an image around a cylinder. But no matter how many different ways I have tried, the image keeps being distorted.
I made sure that the image is the same width as the cylinder’s circumference, and I also matched the height to the cylinder’s extrusion.
I checked the Areas as well, the projected image is 0,01m2 larger than the cylinder - possibly a rounding difference?
I have also aligned the image “properly” to the cylinder.
Below image shows the distortion:
Any help will be much appreciated, as always of course!
Try to use "decal " , and see the result.
bmike
December 8, 2024, 12:28pm
4
Where is this “decal” in SketchUp?
Thanks, the technique with applying the texture to the different segments did work.
Thanks, that’s a good idea. I’m using D5, but I think if I import the texture in there it should give me the same options.
Might even be a better way, as I have a couple of these labels with different graphics that all need to be rendered in the same perspective.
Potential time saver!
bmike
December 8, 2024, 12:41pm
8
Yes, but this is tagged as SketchUp. You could at least add part of your reply to mention a plugin.
DaveR
December 8, 2024, 1:25pm
9
Just a note on your projected image. Projecting the texture image is not appropriate for what you are doing. The distortion you show should be expected when projecting a texture onto a cylinder.
