Hi, I upgraded from SU8 to SU 2015 free ver.
Im trying to make a pattern of flat objects and need to move them around to create even, small gaps between them. Im using a template with measurements in metres.
When I try to move an object, a square 600mm by 600mm away from another by 20mm I select the square and drag it away from the other. It does not move until the curser is 500mm away and then the square snaps to 1 metre away. This is a massive hassle when working in small dimensions.
I need to turn off this snapping to a preset dimension but I can not find anywhere to change this.
Please can someone let me know how to stop this happening.
