I’m trying to project an image seamlessly across two flat surfaces, however my method is not producing the right result (as seen in the attached image). The image is distorting on one of the surfaces.
My method: I created a sample surface with the chosen image texture and set it to ‘projected’ under the texture contextual menu. Then I took a texture sample from the projected sample surface and tried applying it to the two selected objects.
Please can someone tell me how to do this correctly?
For that I wouldn’t use a projected material. What you are showing is exactly what projecting the texture should do. Instead, apply the texture as non-projected.
Texture sampling though is not so intuitive on a mac, it took me a while to figure out that the texture-eyedropper is hidden under Paint bucket + Command
