I have been trying to import a shape map (tree location map) into sketchup using the shapefile extension. But everytime I click continue nothing come up. Does the shape file automatically geolocate it self? I have attached link to the shape file. Also, can I merge the data on to terrain (on a hill), so I will know where the trees are on a slope.
Could you send me the link the website you are using? I have tried import dxf file of this map into SketchUp but they are not scaled and in the right position and they are all guide points.
thats the link for all the files. I do not mind it being a guide point but i cannot align it with the closest z plane with an extension to make them lie on the terrain. So if i set it to meter it will be in scaled? I dont know if i will lie on the position it supposed to be. I have geolocate my model on sketch and i think the data has its coordinate system as well since i didnt have to relocate it on autocad and argis pro
Ok I will try the geolocation part when I get home. May I ask what is that component extension for? I also thought shp file has its own coordinates inside right?
s4u to components is an extension that turns your points into a component, and then you can replace the component with another one (a tree for example).
what kind of scale do you have here? mine is not in scale and not geo located. But when I transfer the file using the website you suggested, it does show the location correctly.
Sorry, also is there any alternative plugin that does not require to pay
SketchUp uses the same lat/long system that, for instance, Google Maps or Google Earth does. National grids are just that, national, and there is no global grid system, naturally.
