Oups ! Link to document with error list has disapeared.
Error: #<SyntaxError: /users/liramdo/library/application support/sketchup 2014/sketchup/plugins/rs_window/setofprofiles_class.rbs:84: syntax error, unexpected ‘:’, expecting keyword_then or ‘,’ or ‘;’ or ‘\n’
when “TLV” : default_code = profile_from_…
/users/liramdo/library/application support/sketchup 2014/sketchup/plugins/rs_window/setofprofiles_class.rbs:85: syntax error, unexpected ‘:’, expecting keyword_then or ‘,’ or ‘;’ or ‘\n’
when “TRV” : default_code = profile_from_…
/users/liramdo/library/application support/sketchup 2014/sketchup/plugins/rs_window/setofprofiles_class.rbs:86: syntax error, unexpected ‘:’, expecting keyword_then or ‘,’ or ‘;’ or ‘\n’
when “SLV” : default_code = profile_from_…
/users/liramdo/library/application support/sketchup 2014/sketchup/plugins/rs_window/setofprofiles_class.rbs:87: syntax error, unexpected ‘:’, expecting keyword_then or ‘,’ or ‘;’ or ‘\n’
when “SRM” : default_code = profile_from_…
/users/liramdo/library/application support/sketchup 2014/sketchup/plugins/rs_window/setofprofiles_class.rbs:88: syntax error, unexpected ‘:’, expecting keyword_then or ‘,’ or ‘;’ or ‘\n’
when “DOM” : default_code = profile_from_…
/users/liramdo/library/application support/sketchup 2014/sketchup/plugins/rs_window/setofprofiles_class.rbs:89: syntax error, unexpected ‘:’, expecting keyword_then or ‘,’ or ‘;’ or ‘\n’
when “DBV” : default_code = profile_from_…
/users/liramdo/library/application support/sketchup 2014/sketchup/plugins/rs_window/setofprofiles_class.rbs:90: syntax error, unexpected ‘:’, expecting keyword_then or ‘,’ or ‘;’ or ‘\n’
when “KOV” : default_code = profile_from_…
/users/liramdo/library/application support/sketchup 2014/sketchup/plugins/rs_window/setofprofiles_class.rbs:91: syntax error, unexpected ‘:’, expecting keyword_then or ‘,’ or ‘;’ or ‘\n’
when “KBV” : default_code = profile_from_…
/users/liramdo/library/application support/sketchup 2014/sketchup/plugins/rs_window/setofprofiles_class.rbs:92: syntax error, unexpected ‘:’, expecting keyword_then or ‘,’ or ‘;’ or ‘\n’
when “DOV” : default_code = profile_from_…
/users/liramdo/library/application support/sketchup 2014/sketchup/plugins/rs_window/setofprofiles_class.rbs:93: syntax error, unexpected ‘:’, expecting keyword_then or ‘,’ or ‘;’ or ‘\n’
when “DBM” : default_code = profile_from_…
/users/liramdo/library/application support/sketchup 2014/sketchup/plugins/rs_window/setofprofiles_class.rbs:94: syntax error, unexpected ‘:’, expecting keyword_then or ‘,’ or ‘;’ or ‘\n’
when “DON” : default_code = profile_from_…
/users/liramdo/library/application support/sketchup 2014/sketchup/plugins/rs_window/setofprofiles_class.rbs:95: syntax error, unexpected ‘:’, expecting keyword_then or ‘,’ or ‘;’ or ‘\n’
when “DBN” : default_code = profile_from_…
/users/liramdo/library/application support/sketchup 2014/sketchup/plugins/rs_window/setofprofiles_class.rbs:96: syntax error, unexpected ‘:’, expecting keyword_then or ‘,’ or ‘;’ or ‘\n’
when “SRN” : default_code = profile_from_…
/users/liramdo/library/application support/sketchup 2014/sketchup/plugins/rs_window/setofprofiles_class.rbs:97: syntax error, unexpected ‘:’, expecting keyword_then or ‘,’ or ‘;’ or ‘\n’
when “SLN” : default_code = profile_from_…
/users/liramdo/library/application support/sketchup 2014/sketchup/plugins/rs_window/setofprofiles_class.rbs:98: syntax error, unexpected ‘:’, expecting keyword_then or ‘,’ or ‘;’ or ‘\n’
when “NLM” : default_code = profile_from_…
/users/liramdo/library/application support/sketchup 2014/sketchup/plugins/rs_window/setofprofiles_class.rbs:99: syntax error, unexpected ‘:’, expecting keyword_then or ‘,’ or ‘;’ or ‘\n’
when “NRV” : default_code = profile_from_…
/users/liramdo/library/application support/sketchup 2014/sketchup/plugins/rs_window/setofprofiles_class.rbs:100: syntax error, unexpected ‘:’, expecting keyword_then or ‘,’ or ‘;’ or ‘\n’
when “NLT” : default_code = profile_from_…
/users/liramdo/library/application support/sketchup 2014/sketchup/plugins/rs_window/setofprofiles_class.rbs:101: syntax error, unexpected ‘:’, expecting keyword_then or ‘,’ or ‘;’ or ‘\n’
when “NRT” : default_code = profile_from_…
/users/liramdo/library/application support/sketchup 2014/sketchup/plugins/rs_window/setofprofiles_class.rbs:102: syntax error, unexpected ‘:’, expecting keyword_then or ‘,’ or ‘;’ or ‘\n’
when “NLV” : default_code = profile_from_…
/users/liramdo/library/application support/sketchup 2014/sketchup/plugins/rs_window/setofprofiles_class.rbs:103: syntax error, unexpected ‘:’, expecting keyword_then or ‘,’ or ‘;’ or ‘\n’
when “NRM” : default_code = profile_from_…
/users/liramdo/library/application support/sketchup 2014/sketchup/plugins/rs_window/setofprofiles_class.rbs:104: syntax error, unexpected ‘:’, expecting keyword_then or ‘,’ or ‘;’ or ‘\n’
when “NOM” : default_code = profile_from_…
/users/liramdo/library/application support/sketchup 2014/sketchup/plugins/rs_window/setofprofiles_class.rbs:105: syntax error, unexpected ‘:’, expecting keyword_then or ‘,’ or ‘;’ or ‘\n’
when “NBV” : default_code = profile_from_…
/users/liramdo/library/application support/sketchup 2014/sketchup/plugins/rs_window/setofprofiles_class.rbs:106: syntax error, unexpected ‘:’, expecting keyword_then or ‘,’ or ‘;’ or ‘\n’
when “NOT” : default_code = profile_from_…
/users/liramdo/library/application support/sketchup 2014/sketchup/plugins/rs_window/setofprofiles_class.rbs:107: syntax error, unexpected ‘:’, expecting keyword_then or ‘,’ or ‘;’ or ‘\n’
when “NBT” : default_code = profile_from_…
/users/liramdo/library/application support/sketchup 2014/sketchup/plugins/rs_window/setofprofiles_class.rbs:108: syntax error, unexpected ‘:’, expecting keyword_then or ‘,’ or ‘;’ or ‘\n’
when “NOV” : default_code = profile_from_…
/users/liramdo/library/application support/sketchup 2014/sketchup/plugins/rs_window/setofprofiles_class.rbs:109: syntax error, unexpected ‘:’, expecting keyword_then or ‘,’ or ‘;’ or ‘\n’
when “NBM” : default_code = profile_from_…
/users/liramdo/library/application support/sketchup 2014/sketchup/plugins/rs_window/setofprofiles_class.rbs:110: syntax error, unexpected ‘:’, expecting keyword_then or ‘,’ or ‘;’ or ‘\n’
when “SLP” : default_code = profile_from_…
/users/liramdo/library/application support/sketchup 2014/sketchup/plugins/rs_window/setofprofiles_class.rbs:111: syntax error, unexpected ‘:’, expecting keyword_then or ‘,’ or ‘;’ or ‘\n’
when “SRP” : default_code = profile_from_…
/users/liramdo/library/application support/sketchup 2014/sketchup/plugins/rs_window/setofprofiles_class.rbs:112: syntax error, unexpected ‘:’, expecting keyword_then or ‘,’ or ‘;’ or ‘\n’
when “DOP” : default_code = profile_from_…
/users/liramdo/library/application support/sketchup 2014/sketchup/plugins/rs_window/setofprofiles_class.rbs:113: syntax error, unexpected ‘:’, expecting keyword_then or ‘,’ or ‘;’ or ‘\n’
when “DBP” : default_code = profile_from_…
/Users/liramdo/Library/Application Support/SketchUp 2014/SketchUp/Plugins/RS_Window/RubyWindow_Start.rb:16:in eval' /Users/liramdo/Library/Application Support/SketchUp 2014/SketchUp/Plugins/RS_Window/RubyWindow_Start.rb:16:in require’
/Users/liramdo/Library/Application Support/SketchUp 2014/SketchUp/Plugins/RS_Window/RubyWindow_Start.rb:16:in <top (required)>' /Applications/SketchUp 2014/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in require’
/Applications/SketchUp 2014/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in load' /Users/liramdo/Library/Application Support/SketchUp 2014/SketchUp/Plugins/RS_Window.rb:20:in register_extension’
/Users/liramdo/Library/Application Support/SketchUp 2014/SketchUp/Plugins/RS_Window.rb:20:in <module:RubyWindow>' /Users/liramdo/Library/Application Support/SketchUp 2014/SketchUp/Plugins/RS_Window.rb:10:in <top (required)>’
Error Loading File /Users/liramdo/Library/Application Support/SketchUp 2014/SketchUp/Plugins/RS_Window/RubyWindow_Start.rb
Error: #<NameError: uninitialized constant RubyWindow::SetofProfiles_Class>
