How to get materials in library to show flat '25?
How do I get materials in the '25 library to display flat, not as a cube?
It would be nice to just display them without the cube. The updated textures are good, it’s just that the cubes makes it so tiny that one doesn’t see the actual texture any longer. @RichardJeffrey → I am using the 5D+ Library as a material picker of choice by now. Nice, full tiles where you can see your texture and compatible with the new textures, too. Give it a try!
I did find that you could just uncheck metalness and/or roughness to pull them back to flat! But are you saying there is no switch? That seems totally illogical!
Like most sketchup users, I export to render and use low res placeholders for materials just as probably 90% of users!
I’d actually say essential! 5D+ looks like a good solution, and huge thanks!
I believe if you go into preferences you can turn off the auto conversion to the new materials when you open an old file…. But I’m out of office today so can’t double check.
