I used the follow me tool on a shape which is just a rounded rectangle on one end. I pulled it up to the edge of the slope, and now I need to cut that part off so its flush with the angle. Is there an easy way to do this? I’ve done it easily with square objects but the roundness is more tedious.
It’s hard to tell exactly from your screen shot but I expect if you select all of the geometry, right click on it, and choose Intersect Faces>With Selection you should be able to then erase what you don’t need.
Thank you. That worked like a charm
