I have a pict attached. I’m trying to simply cut out this little notched in the vertically laid 2x4’s so i can eventually do the same to the horizontal piece and join them together.
I drew in the space I want to delete but I hit DELETE and only the drawn square disappears. Nothing from the vertical 2x4 gets deleted.
What i did was drew an rectangle on the face of the edge of the vertical 2x4. When I pushed in it just created a box inside the 2x4 as shown in the picture. It didn’t actually remove the waste.
There’s no need to explode the group. Just open it for editing before making the change. And if you use components instead of groups, you can notch the ends of all of them in a swell foop.
