Hello, I made a folder with materials
some materials are jpeg filles
how to make this folder (100items) in to skm files
my email : vid@proximus.be thanks
you have at least four choices on a macā¦
use the Color panel in SU to add them one at a timeā¦
find an Extension that works for your version of SU on a macā¦
find and run some ruby code in āRuby Consoleāā¦
Write your own ruby code or extensionā¦
you should add your SU version to your forum profileā¦
what else is in the folder and where is it kept?
john
Thanks John,
there are 100 jpgās 1 @a time
no where to find any extention
no rubyās to find for my problem
How to do this?
This may help:
I have working code for SU v18, but you still havenāt said which version you useā¦
john
Itās a secret.
su podium 2.5.802
or whatās SU ?
S ketch U pā¦
john
Have tried this, extension is .rb not .rbz
I made it .rbz myself after this error installing extention
massmaterialimporter.rb
What steps did you use to make it .rbz?
Yes its version 2018 thanks
Please edit your profile to include that information.
change name rb to rbz
That doesnāt make the file readable by SketchUp so itās no wonder youāre having problems. Put the RB file into a ZIP and rename ZIP to RBZ.
Wrong method! You need to create a zip file containing the rb and then change the extension from .zip to .rbz.
Ok thanks, now extention is instaled, problem ā> unsigned and not showing while enabled
That plugin is quite old and hasnāt been touched in a long time (since 2005). I didnāt write it and havenāt installed it, so I donāt know whether it is still compatible with recent versions of SketchUp, which use a newer version of Ruby since when that was written. It is an old style plugin that does not register itself as an extension, and predates the signing system. You will need to restart SketchUp to cause it to load. It will show up as an item named āImport Materialsā in the Extensions menu.
