I need to apply an image onto a curved surface and the Youtube videos aren’t doing the trick.
Please take a look at this skp. The image is SEARFARI WHALE SUB logo. The surface is the left side of that grey hull.
I exploded the image but I cannot figure out how to project it in the correct place.
Can someone please help?
Joel IMAGEQ2.skp (729.3 KB)
One thing complicating your model is the fact that you have one material/color on the underlying surface … and the logo image your are applying is a .PNG image with a transparent background.
Thus, if the logo image with the transparent background is applied to the appropriate rectangle on the curved surface … the “surface” around the logo will be transparent … which is a bit problematic.
At least two ways to resolve this.
Edit the logo image so that the background is the correct color … same as the color being applied to the rest of the surface. This NOT what I did in the example.
Apply the logo image (with the transparent image) to an appropriate rectangle “above” the rest of the surface … in this case < 1 mm.
I can imagine drawbacks to each scheme … so the “best” scheme will depend upon how you plan to use the SketchUp model.
