How do I remove Fredo6's BezierCurves from my SketchUp Pro 2016?
Hello guys. I’ve never had this problem before. I need to download Fredo6’s “Bezier Curves” (no knock on Fredo6, I use many of his other Ruby Scripts) it’s just that with the Bezier Curves, I’ve found that I have better results with Jacob Samuel’s five or six ruby script Bezier Curve codes. It’s just personal preference, they make more sense to me.
But I don’t know how to get Fredo’s Bezier Curves out of the SketchUp program because I have always used the Extension Store or the SketchUcation Warehouse’s Plugin “popper”.
So, could someone help me with 2016?
Hello. :slight_smile: Installed plugins are removed manually from the Plugins folder. Navigate to C:/Users/YourUsername/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins. Most of the time you have to delete 2 things. The RB file of the plugin and a folder with the same name. Good luck!
For starters, you can also stop unwanted plugins from loading by disabling them in Window menu>Preferences>Extensions.
Anssi
Thanks, I used your suggestion because I am no good at figuring out what the title of the Plugin was (sorry VahePogossian), plus it’s just so darn easier for someone like me, who is visual, to pop out the box of Extensions and disable “bezierspline” (that was my guess and it was right, thank God).
And the idea is that you can re-enable them later if you need them.
Anssi
Thanks.
