How do I force Sketchup application to use my NVIDIA Card
I am reference the information I received below, but don’t know how to force Sketchup to use my NVIDIA Card
Warning: SketchUp has detected you are using () when your system is capable of using an AMD or NVIDIA graphics card () . SketchUp will likely perform better if you change your system to use the AMD/NVIDIA card.
In a system with multiple GPUs, SketchUp will likely perform better on an AMD or NVIDIA GPU than on a GPU from another vendor. If you see this warning, use your graphics card vendor software to force the SketchUp application to use your AMD or NVIDIA card.
I am unsure of where the NVidia control panel is. Can you be more specific on where to locate this?
Right click on the desktop.
It is an Nvidia utility installed with the driver package (usually).
If you cannot find it check the Nvidia support website.
I find a GeForce menu but still unsure how to make it select Sketchup
http://www.nvidia.com/object/performance_group.html
3D Settings -> Manage 3D Settings -> Program Settings (tab) -> SketchUp.exe
Google Search: “nvidia control panel program settings”
YouTube Video: “Nvidia Control Panel Settings Explained - How to Use Manage 3D Settings”
Try r-clicking on your SU desktop shortcut. You may have a menu option to chose your graphics option for SketchUp there.
