How do i draw rectangles a specific size please
Is this not available without paying?
No. You can do this for free. Start the Rectangle tool, click to set the first corner and then drag out to make a rectangle. Type the dimensions you want and hit Enter. This is a very basic operation. You should look at the tutorial videos available at sketchup.com and learn how the program works.
As DaveR says, ā€œjust type in the sizeā€ā€¦
BUT, also note this… you must type in the size immediately after picking the second corner, and you must separate the length and width with a comma and press the [enter] button to confirm the size.
If you live in a locale where you type a comma as a decimal point then you need to use a semicolon instead.
So in the USA, UK, Aus etc it’s:
1.23,4.56
but in Latin countries and much of the EU it’s:
1,23;4,56
Only ever include a space in your typed in dimensions if you are inputting fractional inches, e.g.
1'2 3/4"
Don’t put them after the separating comma/semicolon…
You don’t need to include a units suffix [unless it’s in '/"], because SketchUp assumes a typed in number is in the current Model Info > Units, but if you do add a suffix it is converted anyway - so if you are working in meters and type 10 it assumes 10m, but you can type in 100mm and SketchUp draws that line 0.1m long - making live much easier
Tip: draw an approximation of the desired rectangle, so the bigger dimension is obvious on screen, and you can also see which dimension is which in the current text displayed in the Measurements box, so you'll know which order to type the sizes in - sometimes which is the length and which is the width might not be obvious, especially in 3d space...
thanks to you both i think i have a lot of learning to do
Hi, Also new on SketchUp.
I live in Belgium and also use the free web based version.
If I type in for exc. 100,5;80,8 for a rectangle, SketchUp draws a rectangle of 100x80 without the decimals.
In the settings its in decimal Cm’s.
Thanks in advance,
D.
Check what your regional setting show for a decimal point, normally when you have the ; as the divider it is a , for the decimal, but it may be a .
See down right in the measurements field on your screen ( in my case , as divider between X and Y values and . for decimal point)
And you can change display settings in ā€˜Model Info’ (in my case cm and one decimal (equals mm))
Display precision does not impact SketchUp’s precision!
btw: best to also disable ā€˜Length snapping’ in ā€˜Model Info’ to make modeling easier.
how do you type in the amount of square feet instead of the dimensions because you might have to make a shape that is not a perfect square like a plus sign
A square feet size could be an octopus.
Sketchup is a 3d modelling software that requires your to input specifics, it is not AI that somehow guesses what you want it to do.
To make a plus sign you could draw a rectangle and copy rotate it around it’s midpoint. One of many ways.
So you want to type the area and sketchup must guess the shape of the figure you want.
You can’t just enter the area and as @Box indicated, you can’t just specify the dimensions of a shape by area. There’s an infinite number of shapes that all have the same area.
I made a rectangle as a Dynamic Component that scales itself according to one determined side and the desired area. These are the minimum input data.
