Hi. I am a beginner and creating a 3D letter model now. Is there an easy way to create a centerline between two curves? Please see picture. The red line is the centerline I want to create. Thanks!
This is not a centerline. A centered ridge is a better description.
This is similar to creating 3D hip roofs.
But this is made more difficult because there are at least 4 different curves on the inner perimeter.
Perhaps 3 still different curves on the outer perimeter. (This means offset is unlikely to work well.)
Let us hope one of Fredo’s extension can help here.
You could try this way:
-see how you can create the effect in photoshop -
-insert in SketchUp the image of the letter created in Photoshop;
-follow the tutorial below -
I used the Fredo6 BezierSpline
and Curviloft
plugins and Google SketchUp 8
Thanks! I learned a lot from your video! Thanks again!!!
Thanks! I will try that plugin. Thanks for your help!!!
I didn’t use any plugin…
