I need to impose the herringbone pattern onto the cabinet door faces. I’m new to SketchUP and to forums like this, I’m sorry if a simple search would have given me the answer, but honestly I’m not sure what to search for… The herringbone pattern is flat, the cabinet door is .75 thick with the center being offset back 3/8 of an inch. The cabinet door is a component.
Another way would be to drag the geometry pattern you have into the face you want and it should merge.
If either the geometry of the face or the pattern is grouped, you have to explode one into the face of the other. This merging only happens with edges and faces, not between groups/components nor groups/components into faces/edges.
You can also copy paste geometry into a group.
After merging, excess geometry must be erased. Eraser tool or select and delete.
