Hello, I have been running into an issue with my Door Dynamic Component. In the model, I have it working exactly how I want. However, when I try to save the dynamic component and get it added to my component library, the component doesn’t work in other models when I load it in. When I load the component into the file where the original component was created, it works well. When I load it into other sketchup files, the component doesn’t work as expected. The frame doesn’t size correctly and the positions are off. Many times when I tried to get this problem fixed, I would load the saved door component into other models and the option to make changes on the dynamic wouldn’t even be there.
If someone could help me resolve this issue, I would greatly appreciate it. The main goal is to be able to have this component working the same way it is in its original file location (IsoStore Door HD1) as it does when I import it into other models. Thanks in advance for the help!
IsoStore Door HD1.skp (648.1 KB)
