Hi, I posted ad extension in warehouse with license, now it is active and it is possible to download it but, after installation someting is wrong with licensing.
Sketchup pops me up the message with the “not licensed” error message.
this is the main code of the plugin where I call the “Sketchup::License” (I only replaced the relevant names of directory, files and module):
## ## Main file "myplugin.rb" located in Sketchup plugins directory ## require 'sketchup' require 'extensions' require 'langhandler' require 'json' require 'uri' require 'date' module Myplugin unless file_loaded?(__FILE__) PLUGINPATH = File.expand_path( File.dirname(__FILE__) ).to_s + "/myplugin/" Sketchup::require File.join(PLUGINPATH, 'plugin_config') ## Sets only CONSTANTS for my Module def self.load_extension myextension = SketchupExtension.new APPLICATION_TITLE.to_s, "myplugin/myplugin_loader" myextension.version = VERSION.to_s myextension.copyright = APPLICATION_COPYRIGHT.to_s myextension.creator = APPLICATION_CREATOR.to_s myextension.description = APPLICATION_DESCRIPTION.to_s Sketchup.register_extension myextension, true end load_extension file_loaded(__FILE__) end end#module ## ##----------------------------------------------------------- ## ## Loader file "myplugin_loader.rb" located in "Sketchup plugins directory"/myplugin module Myplugin if (Sketchup::Licensing.get_extension_license('the id obtained from extension warehouse')).licensed? ..... do something else .... do something else end end#module
Is this correct?
I verified that the extension ID is correct and the plugin is in trial mode in “my extensions” on warehouse!
Someone could Help me?
tnk’s
