Hello,
This morning, I started to re work on a Layout file of 45 pages and the document is bugging, problem of appearance and slowness.
I worked in the “Trame” format (In FR, don’t know the word in ENG) so in the low definition format but when finishing my document I turned each pages in hydride format. I cleaned the file so there was no specific issue working on it, even if in Hybrid.
This morning I just wanted to do a few modifications. And I troubles on each pages : problem of hidden things which were appearing / warning icon on some of them. this I managed to handle on turning off/on some “balise”.
But the slowness reminds for no reason which is a nightmare doing my modifications as it takes ages. Like 5 long minutes for each refresh. is ether anything I can do ? I turned the pages concerned by the changes in “trame” again but as the other pages are still in hybrid it does not seem to help when I save. Should I turn back the whole document in low def ??
Thx,
Maya
Keep it in raster, use the hybrid override in document settings so that on export it will write the PDF in hybrid.
One option is to keep all viewports in Raster, with Medium display resolution, and then use the Hybrid output override setting, with output resolution to High.
Thank you for the advise. Where can I change these settings ? Could you please send me a screenshot of where to do the changes ? Many thx
Great.
oui, c’est ça - now just put all your LO viewports back to Raster, and the updates shouldn’t take as long.
What is the file size of your SketchUp model, out of curiosity?
Oups ; actually I cannot export the file ; it does not come out in pdf…
Abd to answer your question, my SKP file is 122Mo
