Hi Guys.
I’m still very much learning Sketchup, so might be doing something obviously wrong here, but I cannot work out what to do:
I’m trying to make a die for a hole punch, and require a 6mm hole all the way though the object, but the object, but the object isn’t solid in sketchup. How do you make it solid?
On the top of the die, I have lowered on side 0.9mm which is what I require, but then the right hand side ‘wall’ is still there, and if I delete it, the whole chamfered section gets removed, and I’m not sure how to rebuild it.
Does anyone have any tips please how I should be creating this?
I created a cylinder for each section, so three in total, one on top of another. Then drew a 6mm circle on the top, and Push/Pulled it 24mm to make the 6mm hole all the way through.
I then chamfered it, drew the area I then wanted to ‘lower’ 0.9mm, and used the push/pull tool to lower it, which is where I am now, but its not correct obviously.
Die attached:
Die_Test.skp (159.7 KB)
Any help/tips would be great ![]()
Thanks a lot
