Very likely the update to Windows 11 resulted in defaulting to the integrated graphics adaptor. Try right clicking in an empty part of the desktop and opening the Nvidia Control Panel. Make sure SketchUp is included in the Program Settings. It should look something like this:
also make sure SketchUp is installed correctly. That requires right clicking on the downloaded installer and selecting Run as administrator. If you didn’t do that or you don’t know, repair the installation. Right click on the downloaded installer, choose Run as administrator, choose the Repair option.
After you’ve done all that, do a power off reboot of your computer and try opening SketchUp. Any improvement?
Tangent: This might not be the best advice! Windows 10 and 11 have a “feature” where, when you shut down the computer, some of the settings and memory are “saved” in order to generate a faster startup. Doing a “Restart” is the only thing that causes the system to reload itself completely from scratch (unless you disable the fast start “feature” - it’s buried somewhere in the system settings.)
I already opened the Nvidia Control Panel and SketchUp had always been included in the Program Settings… I have done all the things you describe, and nothing…
I have not yet gone for Windows 11. On my ultrabook with MX250 graphics SketchUp runs without errors.
Laptop or desktop computer? Are you using an external monitor? Through a “dock”?
Have you downloaded and installed the latest driver from Nvidia?
Same error here, on an Asus laptop with NVidia GeForce GPU.
After Windows 11 weekly update. Last week I removed GPU Driver and Sketchup worked again, now we need a permanent solution.
This has worked fine for 6 years.
Reïnstalled NVidia Driver from ASUS, at first it works, then after a few hours I come back to the laptop and the error is back!
This is very frustrating as I need to finish a project.
