Is there a way to trim a guideline made with the tape measure tool??
I know that you can draw lines with the tool, but really no way to control its length.
Any advice?
Any advice?
There are a couple of plugins that may do what you want.
Convert to Construction Lines adds a R click context menu to convert a selected edge or edges into a guideline the same length as the original edge.
And there’s another that draws construction lines directly with or without optional guidepoints at its ends.
Have to wait to get access to my computer to find full name and source for these - on my phone at the moment, away from computer.
Guidelines are infinite in length. No option to trim them. You can place guidepoints although the dashed line trailing the point isn’t something you can infer from like you can with guidelines.
Except as I understand it SketchUp for iPad doesn’t have any facility to use extensions at this time.
Oops - Thanks, @DaveR i didn’t notice the category. Quite right - iPad, like Web version, can’t use plugins.
Maybe make a Feature Request to add finite guides to the iPad and Web toolset?
I suppose we could create a guide layer/tag and infer that to be a different line type and use that.
Perhaps we should have a new feature added in so that we could match properties of an entity such as a line with a line type of tag and we could create them that way too.
Any thoughts?
I was about to suggest that as a work around, grouping all those lines, of course, so they don’t get entangled with other geometry. I actually do this a fair amount even in desktop.
A few quick notes about the Tape Measure tool, in case it’s helpful…
When using the Tape Measure tool to create a guide, you can:
Option 1 sounds like it might be helpful for answering the original question.
