Guidelines - Can I use them to start a draw?
Hi everybody.
I have this guides
guides
And I want to draw an arc, something like this.
arc
But it seems I cannot start to draw from the guideline, I mean it doesn’t snap to it, so this is the result.
fault
This is my intention.
myintention
Maybe there is a better and faster way to do that, so all recommendations are welcome.
I forgot to attach the file if someone needs.
example.skp (1.2 MB)
Thank you.
That’s not a guideline (infinite), its a guide point with a tail, you can’t snap to tails.
Get the tape measure tool and use the red/ blue axis to start the guides, then you should get infinite guides not guide points. You can use the intersection of these.
I tried to draw infinity lines but I wasn’t sure why I wasn’t able to.
I think it needs an edge, red/blue axis seems to work like that, so … thank you very much ;).
Yes you need “on edge” inference with the tool to create an infinite guide. (you could use any edge btw)
If you use the tape measure tool from a point, then you create a guide point with a tail.
The guide points are “snapable” so just draw the guide line then keyin the offset distance you want.
Thank you both :wink:
