Tape Measure not creating guide points
Hey there,
I’ve searched the forums and the web but I have yet to find a solution to my problem.
I was using the tape measure tool to help me create guide points but all of a sudden this has stopped work and will for some reason only create guide lines. Here’s a list of the things I’ve tried:
  1. Restarting SketchUp
  2. Testing within a new SketchUp file
  3. Made sure I hadn’t clicked CTRL
  4. Made sure my guide layer was turned on.
Any solutions?
Regards,
Waffle
First, View menu. Check that Guides are enabled.
Second, guide points are created when you start from a point or intersection.
Ahhh, that seems to be the issue. Are there any ways to create guide points without having to start from a point or intersection? I.e. starting from a mid-point.
Easy way is to put a crossing guide line at the midpoint so there’s an intersection.
So a guide line and constitute as an intersection?
An intersection is formed when a guide line crosses an edge. Try it and see for yourself.
