Issues with drawing and using measurements
I am having an issue with being able to actually draw while inputting dimensions or measurements……
I am having an issue and I am not sure how to correct it in term of settings,…
The issue is:
No problem using the tape measure tool to make guidelines at user-defined distances and measurements.
Issue happens when drawing actual entities like lines where I select a point which is the start point and say move along any axis and then select 10’ per se, what I end up with is a line in the direction I cast it in and then a second line which is 10’.
All I want to do is select the point and direction and have a single line the defined length which I have entered.
Any ideas on what settings I need to adjust in SketchUp for iPad?
Are you using just draw or click move click?
Just Draw usually….I have t come to a good method to use click draw click yet.
