I haven’t found an equivalent request in topics about Generate Report.
I’m just starting to use it in SU 2021 (latest .392 version for Mac).
Even if I use Decimal Inches, in customising Generate Report, I still get the inch symbol in the CSV output, and Excel or Numbers won’t sum the lengths.
The Model Info settings of unchecking Display units format is ignored - the unit settings in Generate Report don’t have an equivalent, and should have either by default, or as an option to display units only in the column headings.
I have to use a Text Editor to remove the " symbol, and shouldn’t have to. Please (as I think there is an earlier request) put the length symbol in the column heading, not the length field.
In Numbers,… IF we’re just talking about getting rid of all of the “ characters… the most straight forward method would be to use the Find / Replace command.
Find = “ Replace = [leave this completely empty]
Use the Replace All option… and you’ll strip away every instance of “ in your entire sheet.
… and Make sure to set the Cell Format to Numbers… so that your SUM Formula will work.
