Furnitures size are getting weird
I’m using 2022 version before, it was fine, but I recently upgraded to the 2023 version and now the few furniture size are getting weird.
It’s not components, just a groups.
Not just one object, but all the objects that use these furniture are all size getting weird.
Is it the bug or what?
Any solutions would be appreciated.
Please share an example model. It is hard or impossible to tell from a screenshot.
Can you make a link that will work for anyone with the link? The one you gave says you have to request access.
Also, give a few steps that we should do in the file, that will then show the problem.
Ok. Try this one
There were some scale issues fixed in 2023. It may be that those components had problems that weren’t revealed before. I know you mentioned it just being groups, but if you dig into each thing that looks big, there is a component inside the outer groups.
Do you know which 3D Warehouse models were used? Those models on 3DW may have the scaling problems, I could check those too.
Your model is extremely demanding, mostly I think because it uses a lot of very large materials. I made three versions of the file, with different sized materials, and one with unused items purged. Your original file was 245 MB, and the smaller of my files is only 23 MB.
I also turned off Edge Style/Profiles, to make the model perform smoother.
Thank you for your helping.
These model was provided by the designer.
And it is original design furnitures, So I don’t think it’s in 3Dwarehouse.
Good to know. Do you have the original individual files?
THIS IS THE OLDEST ONE I CAN FOUND.
I’M NOT SURE THIS IS THE ORIGINAL ONE.
