Free Sketchup: Freezes when copying/pasting inside components
Hi there,
I’ve been using the web version of SketchUp for over a year now. Mainly for fun. This week I built a new PC and noticed a problem. When I’m 2 components in, and I try to copy, paste or duplicate, the whole app freezes up and I have to close the entire browser tab. Never had this issue with my old PC (same GPU).
The issue persists with all of my projects. I can still press buttons and return to the overview, but when I open another project, I only see the frozen screen from the previous project.
I have updated every possible HW driver, OS and peripherals.
Cheers!
Can you share an example .skp file where this happens?
two other people reported problems with components in the free version recently
I can’t say if it’s related of just adjacent. What’s odd is that there hasn’t been an update to the web version since late october.
I have the exact same issue, and is the reason why I joined the forum since googling didn’t do anything. I have been using the free version or the old Sketchup Make for a couple years now. File is not crazy large but it becomes unresponsive when I move an object. Quite annoying when you are framing walls and the easiest way to get spacing equidistant involves cloning/moving.
Latest(3).skp (1.8 MB)
I encountered the same issue as you when I opened it in Free. I’ll be curious what others have to say.
Well, guess it’s a relieve my new PC is not the cause it seems. Still sucks and I hope this will get fixed soon.
I was curious about the fact that I could create a model with multiple levels of hierarchy and yet have this problem crop up even though there had not been any recent updates. It turns out that you can create an arbitrarily deep hierarchy with no problems. The only issue is when you enter into a hierarchy level more than 2 deep and try to add a component or copy/move a component existing in that hierarchy level. You can move components at deeper hierarchies, you just can’t add or copy. I have attached a testcase below that goes to 9 levels of hierarchy.
component hierarchy testcase.skp (117.5 KB)
See this SU file. I was able to copy a cube in the sixth level of hierarchy.
component hierarchy testcase - JL - 2024-12-09.skp (114.5 KB)
I used SU Pro to do this.
The problem is not in SketchUp Pro, only in the online versions.
I tested in Pro and there was no problem copying. Then tried in Go and it crashed…
Issue is still present with the online version.
Hi everyone. I wanted to let everyone know that this has been reported directly to our SketchUp Web team. Thank you @36yrdream for providing clear steps to reproduce the issue.
I know it’s not an ideal workaround, but while our developers are working on it, exploding the component or group to the same level or one level above the one being edited does prevent the freezing. Alternately, copying the entity, fully closing out of all levels of the nested component, and then pasting also appears to work without freezing.
I am also seeing this issue as well. I run Sketchup in Chrome and it has been a week or so since I’ve worked in Sketchup Web. I have a fairly complex model of my house I’ve been using to build targets for renovations. Most of the model is three or more component levels deep, so I would assume I should run into this issue immediately. In early December, I was duplicating objects within components without issue. As of yesterday, I could no longer do so. I captured the webevent log in Safari in case anyone is interested.
Hi @chris.stephan, thanks for the post. I just ran a check on our web version and can confirm the issue is still there. I’ll go ahead and log the issue and will bring it up as soon as the rest of the team is back online.
A fix was just deployed. Please give it a try now.
I can confirm it’s working on my end!
Works for me. Thanks for the quick fix!
(post deleted by author)
I’ve removed my post based on finding this in another version - which I was only using while this bug stopped me using the free version.
I’ve also read the previous few posts, which I’d not noticed, and realise this is fixed now in the free version. So I’ll get back to using this.
FYI, I reported it directly to the SketchUp Web team on Dec 6th, so hopefully this helped in getting it fixed. Sorry to ruffle feathers on this forum.
No worries.
Don’t forget to report your findings in the other place where we discuss about the other version :wink:
Can confirm on my end that the freezing seems to be resolved on the free version. Thank you to the SketchUp team and everyone contributing!
